TwinTurbo.NET: Nissan 300ZX forum - Re: Boost leak via smoke or fog machine
Subject Re: Boost leak via smoke or fog machine
Posted by induetime on May 12, 2008 at 12:54 AM
  This message has been viewed 153 times.
In Reply To Boost leak via smoke or fog machine posted by spyhunterTT + 93Vert(nj) on May 11, 2008 at 05:48 PM
Message I don't think a "Smoke" machine (called a hazer in the higher end markets) is a good idea, same with the fog machine. However there are dry ice fog machines that should not leave anything behind that the others would. Read through these web sites and find the MSDS reports and see what you would be putting in your intake:
[ www.reelefx.com/products/df50.htm ]
[ www.lemaitrefx.com/indexx.php ]
[ www.martin.com/productgroup/productgroup.asp?psg=fluids&selgroup=82 ]
[ www.americandj.com/ProductDetails.aspx?Category= ]
[ www.americandj.com/ProductDetails.aspx?ItemNumber=1238&Category=Fog_Haze_Machines&txtSearch=fog ]
The one that I would use is this, an Aquafog3300:
[ www.citytheatrical.com/fog3300.htm ]
It can be rented for a couple hundred dollars on a weekly basis. Some rental houses might let you use it for an hour. Cash under the table will or beer will help negotiate with the warehouse workers.
You can start looking here for a rental house:
[ www.epdweb.com/search.php?section=28 ]
Hope this helps.
